Programmable Devices
21602 讨论
VGA - horizantal sync pulse generation
名誉分销商 II
2,850 次查看
hey,
I am trying to generate horizantal sync pulse with FSM.
I write the next verilog code:
module horizantal_sync_pluse ( clock, //system clock reset, //system reset sync_pulse //horizantal sync pulse ); //State machine parameters parameter Scan_Line=1'b0; parameter Gen_Sync_Pulse=1'b1; //---------------------------------- input clock; input reset; output sync_pulse; reg sync_pulse; reg state; reg counter; always@(posedge clock, negedge reset) begin if (reset==0) begin state<=Gen_Sync_Pulse; sync_pulse<=1'b0; end begin case (state) Gen_Sync_Pulse: if (counter==11'h00BC) begin //188 counter<=counter+1'b1; state<=Gen_Sync_Pulse; sync_pulse<=1'b0; end else begin state<=Scan_Line; end Scan_Line: if (counter==11'h639) begin sync_pulse<=1'b1; counter<=counter+1'b1; state<=Scan_Line; end else begin state<=Gen_Sync_Pulse; counter<=0; end default: state<=Gen_Sync_Pulse; endcase end end endmodule
after compilation I get Warning: Latch counter[0] has unsafe behavior
Warning: Ports D and ENA on the latch are fed by the same signal sync_pulse~5
This warning is on each bit of the counter.
why is it? how can I avoid it?
0 项奖励
7 回复数
名誉分销商 II
1,465 次查看
I haven't done verilog for years but I think you got simple error,
if reset == 0
begin
end
else begin // you should put else here
0 项奖励
名誉分销商 II
1,465 次查看
Thanks. it happens to me sometimes, skip on this or that word. very diffecult to find asuch mistake by myself.
Thanks again
0 项奖励
名誉分销商 II
1,465 次查看
Another question.
I would like define
But I don't want that it will be showed in block diagram as parameter to change.
please see atachment.
How can I do it?
0 项奖励
名誉分销商 II
1,465 次查看
Well you can just not declare the unwanted parameters and use their assigned values directly in your code to replace their names.
Parameter is for helping code readability/updating only. At compile time they are replaced by its value.
0 项奖励
名誉分销商 II
1,465 次查看
--- Quote Start ---
I would like define
How can I do it?
--- Quote End ---
Try
localparam Scan_Line=1'b0;
localparam Gen_Sync_Pulse=1'b1;
Cheers,
Dave
0 项奖励
名誉分销商 II
1,465 次查看
Well Dave, I should add you to the list of My Gurus. So far only FvM and josyb managed to get there.
0 项奖励
名誉分销商 II
1,465 次查看
Hey Kaz,
--- Quote Start ---
--- Quote End ---
You are too kind.
I just happened to see localparam used in some of the Altera Verilog :)
Cheers,
Dave
0 项奖励
回复
