Programmable Devices
21615 Discussions
VHDL ATTRIBUTE ram_init_file ignored
WalterGallegos
To workaround Qaurtus unsuported VHDL constructions; I write
SIGNAL LocalRAM : LocalRAMDesc;
ATTRIBUTE ram_init_file : string;
ATTRIBUTE ram_init_file OF LocalRAM : SIGNAL IS "TestInt.mif";
Quartus RAM summary
RAM Summary report for MCU201923
Tue Jun 18 10:46:09 2019
Quartus Prime Version 18.1.1 Build 646 04/11/2019 SJ Lite Edition
; Table of Contents ;
 1. Legal Notice
 2. Analysis & Synthesis RAM Summary
; Legal Notice ;
Copyright (C) 2019 Intel Corporation. All rights reserved.
Your use of Intel Corporation's design tools, logic functions
and other software and tools, and any partner logic
functions, and any output files from any of the foregoing
(including device programming or simulation files), and any
associated documentation or information are expressly subject
to the terms and conditions of the Intel Program License
Subscription Agreement, the Intel Quartus Prime License Agreement,
the Intel FPGA IP License Agreement, or other applicable license
agreement, including, without limitation, that your use is for
the sole purpose of programming logic devices manufactured by
Intel and sold by Intel or its authorized distributors. Please
refer to the applicable agreement for further details, at
https://fpgasoftware.intel.com/eula.
; Analysis & Synthesis RAM Summary        ;
; Name        ; Type ; Mode            ; Port A Depth ; Port A Width ; Port B Depth ; Port B Width ; Size ; MIF ;
; LRAM:A2|altsyncram:LocalRAM[0][15]__3|altsyncram_5q71:auto_generated|ALTSYNCRAM ; AUTO ; Single Port     ; 4096        ; 8           ; --          ; --          ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][15]__7|altsyncram_2eg1:auto_generated|ALTSYNCRAM ; AUTO ; Simple Dual Port ; 4096        ; 8           ; 4096        ; 8           ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][23]__2|altsyncram_5q71:auto_generated|ALTSYNCRAM ; AUTO ; Single Port     ; 4096        ; 8           ; --          ; --          ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][23]__6|altsyncram_2eg1:auto_generated|ALTSYNCRAM ; AUTO ; Simple Dual Port ; 4096        ; 8           ; 4096        ; 8           ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][31]__1|altsyncram_5q71:auto_generated|ALTSYNCRAM ; AUTO ; Single Port     ; 4096        ; 8           ; --          ; --          ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][31]__5|altsyncram_2eg1:auto_generated|ALTSYNCRAM ; AUTO ; Simple Dual Port ; 4096        ; 8           ; 4096        ; 8           ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][7]__4|altsyncram_5q71:auto_generated|ALTSYNCRAM ; AUTO ; Single Port     ; 4096        ; 8           ; --          ; --          ; 32768 ; None ;
; LRAM:A2|altsyncram:LocalRAM[0][7]__8|altsyncram_2eg1:auto_generated|ALTSYNCRAM ; AUTO ; Simple Dual Port ; 4096        ; 8           ; 4096        ; 8           ; 32768 ; None ;
Check at MIF column None.
Comments ?
JoanneSinY_L_Intel
Can you share a simple design that we can use to duplicate the error above?
Joanne
