Programmable Devices
21618 Discussions
VHDL code for logarithme
There are somoene that release a vhdl code for log or have any idea about it.
I need any tutorial or helps to start release it.
Thank you.
like log base 2?
this function will return the nearest log2 of a number (but I wouldnt recommend synthesising as a real time function) Its useful for determining how many bits you need for a vector.
function log2(x : integer) return integer is variable temp : integer :=x; variable n : integer := 1; begin while temp > 1 loop temp := temp/2; n := n + 1; end loop; return n; end function log2;
--- Quote Start ---
like log base 2?
--- Quote End ---
Think you very much for your reply,
ok for this function it is clear, but that i need is a function that can execute during a minimum of clock cycle.
ThAnk you
if you need a synthesisable version, I suggest you use a look-up table.
--- Quote Start ---
--- Quote End ---
Ok thank you, already i use LUT, but i search if it is possible to find a synthetisable code for log.
LUT is the easiest. But you should be able to generate the table using a function.
--- Quote Start ---
--- Quote End ---
I generate the LUT through Matlab. And i initialize memory with the generated data.
