Programmable Devices
21613 Discussions
VHDL gcd program
HI,
I written vhdl gcd program when i compile it gives an error.
simulator : open source ghdl simulator
command used : ghdl -a gcd.vhd
library IEEE;
use IEEE.STD_Logic_1164.all;
entity gt is
generic (width: natural);
port(clock,reset,load:in std_logic;
a,b : in std_logic_vector(width-1 downto 0);
done : out std_logic;
y : out std_logic_vector(width-1 downto 0)
end gt;
architecture RTL of gt is
signal A_New, A_Hold, B_Hold : std_logic_vector(width-1 downto 0);
signal A_less_B : std_logic;
begin
Load:process(clk)
begin
if rising_edge(clk)then
if(Reset='0')then
A_Hold <= A_Hold;
B_Hold <= B_Hold;
else if(load = '1')then
A_Hold <= a;
B_Hold <= b;
else if(A_less_B='1')then
A_Hold <=B_Hold;
B_Hold <=A_New;
else
A_Hold <=A_New;
end if;
end if;
end process Load;
begin
sub:process(A_Hold,B_Hold)
begin
if(A_Hold>=B_Hold)then
A_lessthan_B <= '0';
A_New <=A_Hold - B_Hold;
else
A_lessthan_B <= '1';
A_New <= A_Hold;
end if;
end process sub;
out:process(A_Hold,B_Hold)
begin
if(B_Hold=(others =>'0'))then
Done <='1';
y <=A_Hold;
else
Done <='0';
y <=(others =>'0')
end if;
end process out;
end RTL;
What errors do you get? I see two potential problems:if(A_Hold>=B_Hold)thenYou can't directly compare std_logic_vectors. I recommend to use the ieee.numeric_std library and the unsigned/signed types. Then you can directly use the comparison operator.if(B_Hold=(others =>'0'))thenfilling an array with "others" only work in an assignment, and when the destination has a know size. You can't use it for a comparison either. But if B_Hold is an unsigned/signed then you can compare it with an integer instead:if(B_Hold=0)then
Thanks..i wil try it..
