21615 Discussions
VHDL newbie : configuration file does not compile
Hi !
I wrote a VHDL snippet to test "configuration" VHDL clause (see attached project).
The top level design is configExample.vhd.
I've got this error :
Error (10467): VHDL Component Configuration or Component Instantiation Statement error at configExampleConfig.vhd(30): component "counter4Bits" is used but not declared
Whatever hard I try, I cannot get rid of it !
May I ask you some hints please ?
cheers !
Sylvain
In your configExampleConfig.vhd, use work.all
your configExample_Pkg doesn't declare counter4bits.
Be careful with
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL;
First, They are NOT all IEEE standards (,
Second, 'Unsigned' is always defined in STD_LOGIC_ARITH
Third, I use
LIBRARY ieee; USE ieee.STD_LOGIC_1164.all; USE ieee.numeric_std.all;
Look at http://www.alteraforum.com/forum/showpost.php?p=112092&postcount=10
May it help you.
Dear mmTsuchi,
Many thanks for your answer.
However, it still does'nt compile, I get this message :
Info: Found 2 design units, including 1 entities, in source file src/counter4bits.vhd Info: Found design unit 1: counter4Bits-behavioural Info: Found entity 1: counter4Bits Info: Found 2 design units, including 1 entities, in source file src/configexample.vhd Info: Found design unit 1: configExample-configExampleArchi Info: Found entity 1: configExample Info: Found 2 design units, including 1 entities, in source file src/genericcounter.vhd Info: Found design unit 1: genericCounter-behavioural Info: Found entity 1: genericCounter Info: Found 1 design units, including 0 entities, in source file src/configexampleconfig.vhd Info: Found design unit 1: configExample_conf Info: Found 2 design units, including 0 entities, in source file src/configexample_pkg.vhd Info: Found design unit 1: configExample_Pkg Info: Found design unit 2: configExample_Pkg-body Error (10467): VHDL Component Configuration or Component Instantiation Statement error at configExampleConfig.vhd(30): component "counter4Bits" is used but not declared
May I ask you some hints anew (attached sources with modification you suggested) ?
Cheers !
Sylvain
Hi, look at http://amouf.chez.com/syntaxe.htm#component
I don't know COMPONENT and CONFIGURATION in VHDL. I couldn't help you but I will look at this thread later. It is surely interesting !
i have spent 7 years in writing vhdl without using component and configuration (except some altera's components).
Configurations are rarely used in VHDL. There is no need to use them when you have a single architecture for an entity. And even when you have multiple architectures, there are ways you can select which one to use without having to resort to configurations.
eg. using direct instantiation
my_inst : entity my_lib.some_entity(synth_arch) generic map ( ... ) port map ( ... );
With direct instantiation, its also possible to completly avoid component declarations as well.
Is there any reason you are using components?
--- Quote Start ---
--- Quote End ---
Nevertheless they are supported by Quartus. I've used them with an existing design. I guess, there's a syntax error in the above component configuration declaration, but I'm not aware of the syntax details. Also a limitation of the Quartus configuration feature may exist. Diy you try to compile the code with a different tool, e.g. Modelsim?
Hi FvM !
Modelsim raises the same error report !
Cheers !
Sylvain
Hi Tricky !
I think it's a good way to centralize both the design description and the architecture choices for each component used in a single file.
Then, a new programmer participating to the project after its beginning can refer to this file to get an accurate view of the whole system.
Cheers !
Sylvain
Hi mmTsuchi !
I went through http://amouf.chez.com/syntaxe.htm#component but I still don't detect any mistake in my code...
Cheers !
Sylvain
