21615 Discussions
serial async transmit
hi all
here is my problem...
i would like to connect range sensor to DE2 kit to show results of the range..
the TX output delivers asynchronous serial with an RS232 format, except voltages are 0-Vcc. The output is an ASCII capital “R”, followed by three ASCII character digits representing the range in inches up to a maximum of
255, followed by a carriage return (ASCII 13). The baud rate is
9600, 8 bits, no parity, with one stop bit
i wrote this code just trying to read the first character "R":
--- Quote Start ---
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.components.all;
entity sonar is
port ( din,rst : in bit;
clk : std_logic;
data : out bit_vector (7 downto 0);
data_valid : out bit
end sonar;
architecture rtl of sonar is
signal sample:std_logic;
signal s:std_logic:='1';
begin
m:sampler port map (clk,sample); // dividing the freq//
process (rst , sample)
variable count: integer range 0 to 10; // start+8 data+stop bits //
variable reg: bit_vector (10 downto 0);
begin
if s<='1' then // to make sure the code will be excuted one time//
if (rst='1') then
count:=0;
reg:=(reg'range =>'0');
data_valid <='0';
elsif (sample'event and sample='1')then
if (reg(0)='0'and din='1')then
reg(0):='1';
elsif (reg(0)<='1') then
count:=count+1;
if (count<10) then
reg(count):= din;
elsif (count=10)then
count:=0;
data_valid <='1';
data<=reg(8 downto 1);
end if;
end if;
end if;
end if;
s<='0';
end process;
end rtl;
--- Quote End ---
and this is my sampler
--- Quote Start ---
library ieee;
entity sampler is
port (
clk: in std_logic;
sample: out std_logic);
end sampler;
architecture sam of sampler is
begin
process (clk)
variable counter: integer range 0 to 5000:=0;
begin
if (clk'event and clk='1') then
if (counter=5000) then
counter:=0;
end if;
counter:=counter+1;
if (counter>=4999) then
sample<='1';
else sample<='0';
end if;
end if;
end process;
end sam;
--- Quote End ---
and this is my component
--- Quote Start ---
component sampler is
port (clk: in std_logic;
end component;
--- Quote End ---
after programing i got this result
data='11111111'
could anyone tell me what's wrong?! where is my fault!!
A UART receiver would be expected to oversample the input and synchronize on a start bit. I can't detect this in your code.
Using a divided ("ripple") clock has the disadvantage of causing timing conflicts when transfering the UART output to other design parts. The synchronous clock enable method would be preferred.
--- Quote Start ---
--- Quote End ---
what do you suggest?
--- Quote Start ---
--- Quote End ---
in my code....is there a problem with synchronisation?
thanx FvM.
