Programmable Devices
21615 Discussions
Verify failed between address 0x2000000 and 0x200FFFF
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloading 02000000 ( 0%)
Downloading 02010000 (60%)
Downloading 06008020 (99%)
Downloaded 107KB in 1.8s (59.4KB/s)
Verifying 02000000 ( 0%)
Leaving target processor paused
if anybody have an idea about the problem,please answer me
this can be due to a lot of reasons.
if you use sdram f.e. check the phase of the sdram clock.
have you tried a simple hello world with a minimal system running from internal memories instead of external memory ?
--- Quote Start ---
--- Quote End ---
I had exactly the same problem. Now I tried building a simple project with the simple "Hello_world" code, using only on-chip memory, which should be enough but I get an error message:
make -s all includes
Linking simple.elf...
/cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region onchip_memory2_0 is full (simple.elf section .text). Region needs to be 25408 bytes larger.
/cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [00008020 -> 00008507] overlaps section .exceptions [00008020 -> 000081c7]
/cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [00008508 -> 00009f33] overlaps section .text [000081c8 -> 0001333f]
/cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .bss [00009f34 -> 0000a147] overlaps section .text [000081c8 -> 0001333f]
collect2: ld returned 1 exit status
make: *** [simple.elf] Error 1
Build completed in 18.734 seconds
What is the problem? I'm using a Cyclone III board of version 7.2 while using Quartus 9.1. Could that be the problem?
Memory is too small...
printf/scanf, etc. are quite large.
I had the same problem.
I was using DE2 board, and the problem was with sdram pins. I had to change manually DRAM_BA pins and DRAM_DQM pins. After that fix, the proyect works properly.
--- Quote Start ---
--- Quote End ---
hi, may i know what do you mean by changing the pins? i dont understand. i am having the same problem with sdram.
--- Quote Start ---
--- Quote End ---
Hi.
You need change in Pin Planner:
DRAM_LDQM to DRAM_DQM[0]
DRAM_UDQM to DRAM_DQM[1]
and
DRAM_BA_0 to DRAM_BA[0]
DRAM_BA_1 to DRAM_BA[1]
And then, you can assign these pins to your Nios II as buses.
DRAM_DQM[1..0]
DRAM_BA[1..0]
You must do this because Nios II in SOPC Builder 9.1 SP2 has buses for these connections to the SDRAM
I hope to be clear enough :)
thanks for the info.
