Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 02000000 ( 0%) Downloading 02010000 (60%) Downloading 06008020 (99%) Downloaded 107KB in 1.8s (59.4KB/s) Verifying 02000000 ( 0%) Verify failed between address 0x2000000 and 0x200FFFF Leaving target processor paused if anybody have an idea about the problem,please answer me Thanks,
this can be due to a lot of reasons.
if you use sdram f.e. check the phase of the sdram clock. have you tried a simple hello world with a minimal system running from internal memories instead of external memory ?- Mark as New
--- Quote Start --- this can be due to a lot of reasons. if you use sdram f.e. check the phase of the sdram clock. have you tried a simple hello world with a minimal system running from internal memories instead of external memory ? --- Quote End --- Hi, I had exactly the same problem. Now I tried building a simple project with the simple "Hello_world" code, using only on-chip memory, which should be enough but I get an error message: make -s all includes Linking simple.elf... /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region onchip_memory2_0 is full (simple.elf section .text). Region needs to be 25408 bytes larger. /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [00008020 -> 00008507] overlaps section .exceptions [00008020 -> 000081c7] /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [00008508 -> 00009f33] overlaps section .text [000081c8 -> 0001333f] /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .bss [00009f34 -> 0000a147] overlaps section .text [000081c8 -> 0001333f] collect2: ld returned 1 exit status make: *** [simple.elf] Error 1 Build completed in 18.734 seconds What is the problem? I'm using a Cyclone III board of version 7.2 while using Quartus 9.1. Could that be the problem?
Memory is too small...
printf/scanf, etc. are quite large.
I had the same problem.
I was using DE2 board, and the problem was with sdram pins. I had to change manually DRAM_BA pins and DRAM_DQM pins. After that fix, the proyect works properly.- Mark as New
--- Quote Start --- I had the same problem. I was using DE2 board, and the problem was with sdram pins. I had to change manually DRAM_BA pins and DRAM_DQM pins. After that fix, the proyect works properly. --- Quote End --- hi, may i know what do you mean by changing the pins? i dont understand. i am having the same problem with sdram.
--- Quote Start --- hi, may i know what do you mean by changing the pins? i dont understand. i am having the same problem with sdram. --- Quote End --- Hi. You need change in Pin Planner: DRAM_LDQM to DRAM_DQM[0] DRAM_UDQM to DRAM_DQM[1] and DRAM_BA_0 to DRAM_BA[0] DRAM_BA_1 to DRAM_BA[1] And then, you can assign these pins to your Nios II as buses. DRAM_DQM[1..0] DRAM_BA[1..0] You must do this because Nios II in SOPC Builder 9.1 SP2 has buses for these connections to the SDRAM I hope to be clear enough :)
thanks for the info.
