21601 Discussions
Verifying that a Cyclone V FPGA is good
PDone
I have a cyclone V FPGA Image which no longer runs in my board . This image ran in my board and is still running on other boards. If I reload an earlier image it works fine.
There is no change to the IO. I combined 4 ADC_LVDS DESERIALIZERS into one big ADC_LVDS_DESERIALIZER. The failure is that the clocks no longer work, even those that have nothing to do with the deserializer. I am able to read back a version register which is had coded and does not requite the use os a clock to read. I cannot WRITE to a register and read it back
Therefore I believe that the FPGA is bad.
Is there some kind of test utility I can use to verify this?
a_x_h_75
New Contributor III
There's no magic test utility to check the status of a device. If you have other working boards, using the same FPGA image, then - assuming you have confidence in the hardware - you have a pretty good indication.
'the clocks no longer work...'
What is the source of these clocks? Is it running?
Cheers,
Alex
jrrguzman
@PDone​ The fact that sometimes works (it worked before but not now) or works at other boards but not in this one seems like a timing issue...but I can't tell with just the description you provide.
Try changing the seed for the fitter so the design placement changes as well and you might get a "working design" again.
PDone
There was a loose jumper on the board. Thanks, Pete D.
Rahul_S_Intel1
Hi ,
I hope the problem is solved by providing the Jumpers.
Rahul S
