Programmable Devices
21615 Discussions
Verilog Generate
Hi All,
Does verilog allows to use generate statements inside another generate statement.
I have a requirement as shon below,
generate if (A >1) // A is a top level generic
generate for (i=0; i<10; i=i+1)
begin : START
logic.....
end
endgenerate
endgenerate
The above gives errors while compiling. Any other option to use generate inside another generate.
regards,
freak
genvar i; generate if (A >1) begin// A is a top level generic for (i=0; i<10; i=i+1) begin : START logic..... end end endgenerate
But, we can use for loop only inside a always block. This is a problem.
Please share your thoughts.
regards,
freak
You cannot do a generate inside an always block. You can do an always block inside a generate.
Jake
You could post the code you're trying to make work.
Jake
Thanx Jake. This was a very useful tip.
I have one more query.
Can i have some king of code as shown below. i.e.multiple for loops inside same generate.
Code:
generate if (A >1)
for (i=0; i< 2; i=i+1)
begin : ZEROTOTWO
assign c = a & b
end
for (i=2; i< 10; i=i+1)
begin : twototen
assign c = a & b
end
endgenerate
Please give your thought.
regards,
freak
