21602 Discussions
Verilog XOR incorrect result
I have a state in state machine where a 2568 bit register is XOR'd with 2568 bit parameter. I tried displaying bits[63:0] of the output in the LCD display. Bits[15:0] of the result is incorrect. I also tried displaying the operands of the XOR operation. They are correct. I don't understand why the output is incorrect.
Please advise.
thanks!
Your should post some HDL code if you want someone to give you hints
How's your timing?
