Programmable Devices
21611 Discussions
Verilog to VHDL
Hi everyone,
I am having a problem converting a verilog code to vhdl. I know there is a tool does that but it is not working properly. I did write the code in vhdl and the schematic is same. however the output of the two designs are completely different. I have a doubt about the accumulator, could anyone help me figure out what i am doing wrong here.
`timescale 100 ps / 10 ps `define MSBI 7 // Most significant Bit of DAC input //This is a Delta-Sigma Digital to Analog Converter module dac(DACout, DACin, Clk, Reset); output DACout; // This is the average output that feeds low pass filter reg DACout; // for optimum performance, ensure that this ff is in IOB input DACin; // DAC input (excess 2**MSBI) input Clk; input Reset; reg DeltaAdder; // Output of Delta adder reg SigmaAdder; // Output of Sigma adder reg SigmaLatch; // Latches output of Sigma adder reg DeltaB; // B input of Delta adder always @(SigmaLatch) DeltaB = {SigmaLatch, SigmaLatch} << (`MSBI+1); always @(DACin or DeltaB) DeltaAdder = DACin + DeltaB; always @(DeltaAdder or SigmaLatch) SigmaAdder = DeltaAdder + SigmaLatch; always @(posedge Clk or posedge Reset) begin if(Reset) begin SigmaLatch <=# 1 1'b1 << (`MSBI+1); DACout <=# 1 1'b0; end else begin SigmaLatch <=# 1 SigmaAdder; DACout <=# 1 SigmaLatch; end end endmodule
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.numeric_std.all; use ieee.std_logic_arith.all ; use ieee.std_logic_unsigned.all ; &#12288; entity dac_vhdl is port(clk,reset : in std_logic; DAC_in : in std_logic_vector(7 downto 0); DAC_out : out std_logic); end entity; architecture beh of dac_vhdl is signal Adder1_out : std_logic_vector(9 downto 0):=(others=>'0'); signal Adder2_out : std_logic_vector(9 downto 0):=(others=>'0'); signal Latch_out_sig : std_logic_vector(9 downto 0):=(others=>'0'); signal adder1_in : std_logic_vector(9 downto 0):=(others =>'0'); signal Latch_out : std_logic; &#12288; begin Latch_out<= Latch_out_sig(9); process (Latch_out) begin Adder1_in(9 downto 0) <= Latch_out_sig(9)&Latch_out_sig(9)& "00000000"; end process; process(DAC_in, Adder1_in) begin Adder1_out(9 downto 0) <= DAC_in(7 downto 0) + Adder1_in(9 downto 0) ; end process; process(Latch_out, Adder1_out) begin Adder2_out(9 downto 0) <= Adder1_out(9 downto 0) + Latch_out_sig(9 downto 0) ; end process; process(clk,Reset) begin if(Reset='1')then Latch_out_sig<= "1000000000"; elsif(clk'event and clk='1')then Latch_out_sig(9 downto 0) <= Adder2_out(9 downto 0); end if; end process; &#12288; process(clk,Reset) begin if(Reset='1')then DAC_out<='0'; elsif(clk'event and clk='1')then DAC_out <= Latch_out; end if; end process; end beh;
Both designs are identical, except for one detail. The SigmaLatch initializers have different bit patterns. If you correct the VHDL code respectively, both synthesize to the same gate level code.
Sets this bit pattern:
Latch_out_sig<= "0100000000";
If you are referring to X-HDL, it's performing good I think, but needs either well considered rules or some manual rework.
It's a pure simulation issue.
I was only talking about synthesis results and didn't check your code regarding simulation consistency, but I notice that you have wrong sensitivity list entries. Quartus warns about it.
