Programmable Devices
21615 Discussions
Version 1.4 Released
The Microtronix Nios II Linux Distribution has been updated to support the Nios II 5.0 IDE.
Following is a partial list of changes from v1.3 of the distribution to v1.4:
- The Linux kernel has been upgraded from v2.6.9 to v2.6.11
- Support for the Altera Nios II 2s60 ES Development board is now included
- Support for the Microtronix PSK is also provided.
- The application plug-in was re-written to support the newer version of Nios II IDE (specifically, the newer CDT)
I'll be using this thread to post any updates and bug-fixes that can be applied to v1.4 of the Nios II Linux Distribution. Please feel free to subscribe to this thread to keep notified of these fixes.
Download Link: nios ii linux distribution v1.4 (http://forum.niosforum.com/downloads/1_4/nios2linux-1.4.zip)
The following info is also found within the readme.txt file.
upgrading from v1.x to v1.4
backing up your projects:
To carry your kernel projects forward to the new release, please backup
the <project>/build/.config file to somewhere safe.
To carry forward filesystem and application projects, please backup each
project directory to somewhere safe.
All projects can normally be found in:
...altera/kits/nios2/bin/eclipse/workspace
upgrade procedure:
(1) Uninstall Nios II Linux v1.x.
(2) Follow the upgrade procedures for Quartus II v5.0 and Nios II v5.0
(3) Install Nios II Linux v1.4
restoring a kernel project:
(1) Create a new kernel project using the instructions found within the Quickstart Guide. The procedure hasn&#39;t changed at all since v1.0
(3) Configure the kernel taking all the defaults.
(2) Copy over the .config file that you backed up earlier into the project&#39;s build directory.
(3) Start up Nios II SDK shell and run:
$ cd $ECLIPSE_WORKSPACE/<kernel_project>/build $ make oldconfig
When prompted with new options, select "no" for any new ones that show up. In the case of multi-answer options, using the default value should be safe.
(4) From within the Nios II IDE, try rebuilding the kernel using the build project option.
restoring filesystem projects:
(1) Copy the project directories back into the main workspace directory that you selected when starting up the Nios II v5.0 IDE.
From the Nios II IDE:
(1) Select File->Import... from the pull-down menus
(2) Select "Existing project into Workspace" from the list of options
(3) Click next.
(4) In the next page, select: "Browse..." and select the project directory with your filesystem project.
restoring application projects:
(1) Create a new Application Project using the Nios II IDE.
(2) Copy all the relevant C Source files and Makefiles into your new application project and build.
