21611 Discussions
Vhdl codes for counter to start and purse
I need urgent help on how to design a stopwatch that can stop/purse using vhdl code. I will really appreciate any urgent reply to this.
Waiting for your replies.
Use Quartus -> Right click -> Insert template -> Full design -> Counter
I didnt get what you are saying.
I have designed the counter but I want to work on the stop and start botton on the board to stop/start when i press stop/start without holding the button down.
I will need quick reply from you and other members of this forum.
Add the following lines:
--pseudocode -- on the clock edge if start = '1' then -- or may be '0' depending on key logic start_L <= '1'; elsif stop = '1' then start_L <= '0'; end if; if start_L = '1' then count <= count + 1; end if;
Can you make ce input to be for both start/stop/pause or you separate start, stop and purse as different input logic?
I will appreciate your urgent reply
I assume CE is clkenable. You can apply it to all clocked registers at same time.
can i separate the START AND PURSE with separate input i.e
Start: IN_STD_LOGIC
PAUSE: IN_STD_LOGIC
you can start, stop, reset, freeze reverse,...etc at will by choosing a switch for each decision
is not working out at. I want to the button start to be pressed once and it will purse. I have been able to do it that if i press it down, it will purse. Now I want a code for CLockenable that can stop the counter, like clear it without changing and if i press it again, it should be able to start.
is not working out . I want the button start to be pressed once and it will purse. I have been able to do it such that if i press it down, it will purse. Now I want a code for CLockenable that can stop the counter, like clear it and if i press it again, it should start.
thanks.
in that case it should not be called clock enable.
-- on clock edge
if sw = '1' then
toggle <= not toggle;
end if;
if toggle = '1' then
count <= 0;
else
count up...
you will need to manage the logic of various switches now with care otherwise they might get in conflict. This where simulations helps.
how can i design the clock such that if i press pause at intial state, there should be something to remember that state so that Wwhen i do that, the button will change to the next state i.e 1 to 0.
is majoprly on the start./stop and nothint else. thats all i need for now.
anybody with idea on how to implement this. I need it urgent.
or If you know how to apply flip flop, logic gate to manipulate the start and stop button, I will appreciate it. Thanks
one switch represent start and stop. All I want is that instead of holding the switch down to stop counting, I want it to stop counting if I also remove my hand. and again If I do same thing, i want it to start counting....
Please If you know what I mean, kindly help me out.
The best way to achieve what you are asking is to draw yourself a flow chart. If you are looking for an on/off button with just one push then you would have something like this.
process(clk) begin if(rising_edge(clk)) then button_prev <= button_curr; button_curr <= button; end if; end process Button_pulse <= button_curr AND (NOT button_prev); Now, you can register the pulse, add debounce, ect. It is up to you.
Next, you need to create a state machine to handle the enable to your counter. From what you've described you have 2 states, on and off. you start in the off state, if the button_pulse = 1 then you go to the on state and again if the button pulse is 1 you go back to the off state. Then you describe your counter enable as 1 when in the on state and 0 when in the off. I recommend drawing this out and then creating your state machine to match your diagram.
