21602 Discussions
W914552s SSL76 E1 Spec
Rmcgrath
hi
I need E1 line interface of IC W914552S SSL76.
As E1 framing (multiframe SMCF, etc) and other characteristics.
Farabi
Is this FPGA related issue? please clarify so we can assign to correct owner.
regards,
Farabi
Rmcgrath
Unfortunately I can’t answer due not having information.
I just looking information related to E1 interface, framing, protocol and other technical stuff according international standards I.E. CCITT recommendations, etc.
BoonBengT_Altera
Hi @Rmcgrath,
If unsure if this is FPGA related or not, would you mind to share what product (i.e., hardware/software) are you working with?
Unfortunately we tried to search on your mention keyword but there unable to find relevant product, is it CPU/Graphic/Memory/etc?
Any details on your project would be helpful for us to understand the situation better.
Hope to hear from you soon.
BB
Rmcgrath
Hi, thanks.
The product in question it refers to a hardware category of TDM Telephony interface cards (E1/PRI TDM, FXO Foreign eXchange Office and FXS Foreign Exchange Station) mainly used in Asterisk open source.
My question it refers to china manufactured E1 TDM card which use E1 IC transceiver W914552S SLL76. This IC transceiver connect 30 digital voice channels in frames of 24 or 30 voice channels, plus tow channels one for synchronization and another for voice signaling, multiplexed in a 2 Mbits frame, the process of Multiplexing and coding is based on standards G703, 704, etc.
Tks.
BoonBengT_Altera
Hi @Rmcgrath,
Thanks for sharing the details on the product involved.
As the issues are related to none-FPGA product, hence we would route you accordingly to relevant team.
Appreciated the patients.
BB
IsaacQ_Intel
Hello @Rmcgrath
Our records indicate that we do not have information on any products related to your TDM Telephony interface cards (E1/PRI TDM, FXO, FXS). To better assist you, could you please provide the following details to help us understand your issue more thoroughly:
1.      Can you provide information on the manufacturer of the TDM Telephony interface card in question?
2.      Are there any indications or markings on the card suggesting an affiliation with Intel?
Isaac Q.
Rmcgrath
Well, as search IC product code in google engine it match found as a product developed by Intel.
Matching IC description type with the card IC, unfortunately as not available Intel E1 transceiver datasheet it couldn't check beforehand coincidences.
These types o card mainly are development in China.
1.- Unfortunately the card not have manufactured product information as it’s generic TDM card.
2. - E1 transceiver IC code it indicated as Intel IC manufactured.
B.R.
Mc Grath Ricardo
IsaacQ_Intel
Hello Rmcgrath
Thank you for your reply.
Isaac Q.
IsaacQ_Intel
Hello Rmcgrath
Thank you for your patience.
After a throughout research, this product belongs to FPGA. All product, tools, or technical-related inquiries (e.g. issues debug, thermal resistance data, specification information, quartus, licensing or clarification), Please check in the Intel Community - FPGAs and Programmable Solutions and post a question on the appropriate subforum topic.
 We will move your question to the correct sub-forum, the team in charge will get back to you soon.
Isaac Q.
