21615 Discussions
Wait statement error!!!
when i am using the following code
clk_process: process
begin
clk<='0'
wait for 10 ns;---ERROR COMING HERE
clk<='1'
wait for 10ns;
end process
ERROR IS : WAIT SHOULD COME WITH UNTIL CLAUSE......
One question: are trying to synthetize this code?
nope for test bench...
So, try to do this,
begin
clk<=NOT clk;
wait for 10ns;
end process;
I think this is the better way to generate a clock signal for test bench.
Good luck!!
You forgot semi colons in your code.
How about posting the real code, and the real errors next time.
And Shikata: your code would not work if you forgot to initialise clk - the OP's code will.
Thanks for the tip.
Thaks for the tip!!
