21611 Discussions
Waveform simulation
Hi all.
I have tried this coding and it successful. I want to generate the waveform. But, it does not produce waveform at output port. Could someone tell me why it happens. Thanks in advance
library ieee;
use ieee.std_logic_1164.all;
entity pulse is
port(
clk_in : in std_logic;
--clk_out : out std_logic;
data_in : in std_logic;
reset : in std_logic;
data_out : out std_logic_vector(15 downto 0));
end pulse;
architecture fifi of pulse is
-- Build an enumerated type for the state machine
type state_type is (s0, s1, s2, s3, s4, s5, s6, s7, s8, s9, s10, s11, s12, s13, s14, s15 );
-- Register to hold the current state
signal state : state_type;
--clock divider
signal temporal : std_logic;
signal counter : integer range 0 to 757 := 0;---clock divider utk f=33kHz
begin
frequency_divider: process (reset, clk_in) begin
if (reset = '1') then
temporal <= '0';
counter <= 0;
elsif rising_edge(clk_in) then
if (counter = 757) then
temporal <= NOT(temporal);
counter <= 0;
else
counter <= counter + 1;
end if;
end if;
end process;
--clk_out <= temporal;
--begin
-- Logic to advance to the next state
process (temporal, reset)
begin
if reset = '1' then
state <= s0;
elsif (rising_edge(temporal)) then
case state is
when s0=>
if data_in = '1' then
state <= s1;
else
state <= s0;
end if;
when s1=>
state <= s2;
else
state <= s1;
end if;
when s2=>
state <= s3;
else
state <= s2;
end if;
when s3 =>
state <= s4;
else
state <= s3;
end if;
when s4 =>
state <= s5;
else
state <= s4;
end if;
when s5 =>
state <= s6;
else
state <= s5;
end if;
when s6 =>
state <= s7;
else
state <= s6;
end if;
when s7 =>
state <= s8;
else
state <= s7;
end if;
when s8 =>
state <= s9;
else
state <= s8;
end if;
when s9 =>
state <= s10;
else
state <= s9;
end if;
when s10 =>
state <= s11;
else
state <= s10;
end if;
when s11 =>
state <= s12;
else
state <= s11;
end if;
when s12 =>
state <= s13;
else
state <= s12;
end if;
when s13 =>
state <= s14;
else
state <= s13;
end if;
when s14 =>
state <= s15;
else
state <= s14;
end if;
when s15 =>
state <= s0;
else
state <= s15;
end if;
end case;
end if;
end process;
-- Output depends solely on the current state
process (state)
begin
case state is
when s0 =>
data_out <= "0000000000000001";
when s1 =>
data_out <= "0000000000000010";
when s2 =>
data_out <= "0000000000000100";
when s3 =>
data_out <= "0000000000001000";
when s4 =>
data_out <= "0000000000010000";
when s5 =>
data_out <= "0000000000100000";
when s6 =>
data_out <= "0000000001000000";
when s7 =>
data_out <= "0000000010000000";
when s8 =>
data_out <= "0000000100000000";
when s9 =>
data_out <= "0000001000000000";
when s10 =>
data_out <= "0000010000000000";
when s11 =>
data_out <= "0000100000000000";
when s12 =>
data_out <= "0001000000000000";
when s13 =>
data_out <= "0010000000000000";
when s14 =>
data_out <= "0100000000000000";
when s15 =>
data_out <= "1000000000000000";
end case;
end process;
end fifi;
you havent included "temporal" or counter on the waveform. temporal changes every 757 clocks, which is not shown on the waveform.
But it is bad practice to use a counter to generate a clock. Much better to generate a clock enable and clock the whole system at the source clock frequency.
