Programmable Devices
21602 Discussions
We would like to request for FA
NMinh3
Part Number
AE1818-7675LF
Model
AEE8251-60666LF
Affected SN
1.      E82516066623182500057
2.      E82516066623183200088
3.      E82516066623184500101
4.      E82516066623183800035
5.      E82516066623182500155
6.      E82516066623182700009
7.    E82516066623183000010
Description
PPN of 1818-7675
Quantity
7 pcs
Issue
failed at production due to defective U101
MPN
EPC2LC20N
P/O#
4514783238, 4514819251, 4514851348
DC#
1801, 1807, 1831
Zawani_M_Intel
Thank you for contacting Intel Community. Please be noted that Intel FPGA requires details information for failure analysis request. Please help to answer questions below in order for us to better understand your position. 1. Please provide full device details. 1.1. Device name: 1.2. Full part number: 2. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units. 3. What is the failure symptom? Please elaborate the failure symptom in detail. 4. When did the failure happen? How did you discover the failure? 5. How did you determine the failure? Please elaborate the procedures. 6. Does the failure unit ever working before failure? 7. Did they violate solder re-flow temperature profiles, moisture sensitivity? 8. Did you swap the failure device to a known good board? Is the failure following the device or board? Regards, Wani
NMinh3
Hi, Refer below: 1. Please provide full device details. 1.1. Device name: IC 1.695M-bit EEPROM CMOS 20-PLCC 1.2. Full part number: AE1818-7675LF 2. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units. - 7 / 246 3. What is the failure symptom? Please elaborate the failure symptom in detail. - Test program aborted due to E8251-60666 failed at Store Module Eeprom. [cid:image006.jpg@01D4E0C7.8E40C470][cid:image007.jpg@01D4E0C7.8E40C470] 4. When did the failure happen? How did you discover the failure? - The failure happen while perform Download Firmware. - The test program shown E8251-60666 “Eeprom header read from UUT does NOT match header written to UUT. 5. How did you determine the failure? Please elaborate the procedures. - Refer to the schematic, U101 is the configuration Eeprom. - We have perform measurement VOLTAGE for U101, good vs bad. [cid:image010.jpg@01D4E0C7.8E40C470] U101 Measurement Voltage (V) No U101 GOOD BAD 1 Pin 1 3.35v 3.30v 2 Pin 2 3.38v 3.30v 3 Pin 3 0 0 4 Pin 4 0 0 5 Pin 5 3.26v 3.30v 6 Pin 6 0 0 7 Pin 7 0 0 8 Pin 8 3.30v 0.035v 9 Pin 9 3.30v 0.035v 10 Pin 10 0 0 11 Pin 11 2.8v 2.79v 12 Pin 12 3.26v 3.30v 13 Pin 13 3.30v 3.30v 14 Pin 14 3.30v 3.30v 15 Pin 15 0 0 16 Pin 16 0 0 17 Pin 17 0 0 18 Pin 18 3.30v 3.30v 19 Pin 19 3.30v 3.30v 20 Pin 20 3.30v 3.30v 6. Does the failure unit ever working before failure? No 7. Did they violate solder re-flow temperature profiles, moisture sensitivity? No 8. Did you swap the failure device to a known good board? Is the failure following the device or board? We have done swapping experiment, the failure is following device. Thank you. Regards, Nabilah
NMinh3
Hi Wani, Any update on below request? Pls help to respond this ASAP as we need the disposition on this FA request urgently. Thank you. Regards, Nabilah
Zawani_M_Intel
Hi Nabilah, I am so sorry for late of response as we was on discussion regarding your issue. I will continue support your ERMA case through private message. Thanks! Wani
Zawani_M_Intel
Hi Nabilah, I believed you have received ERMA support through our private message. If you have any concern on your ERMA request, you can drop your note to that private message so we can assist you with your needed. Have a great day! Thanks! Wani
