Part Number
AE1818-7675LF
Model
AEE8251-60666LF
Affected SN
1. E82516066623182500057
2. E82516066623183200088
3. E82516066623184500101
4. E82516066623183800035
5. E82516066623182500155
6. E82516066623182700009
7. E82516066623183000010
Description
PPN of 1818-7675
Quantity
7 pcs
Issue
failed at production due to defective U101
MPN
EPC2LC20N
P/O#
4514783238, 4514819251, 4514851348
DC#
1801, 1807, 1831
链接已复制
5 回复数
Thank you for contacting Intel Community.
Please be noted that Intel FPGA requires details information for failure analysis request. Please help to answer questions below in order for us to better understand your position.
1. Please provide full device details.
1.1. Device name:
1.2. Full part number:
2. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
3. What is the failure symptom? Please elaborate the failure symptom in detail.
4. When did the failure happen? How did you discover the failure?
5. How did you determine the failure? Please elaborate the procedures.
6. Does the failure unit ever working before failure?
7. Did they violate solder re-flow temperature profiles, moisture sensitivity?
8. Did you swap the failure device to a known good board? Is the failure following the device or board?
Wani
Refer below:
1.1. Device name: IC 1.695M-bit EEPROM CMOS 20-PLCC
1.2. Full part number: AE1818-7675LF
- 7 / 246
- Test program aborted due to E8251-60666 failed at Store Module Eeprom.
[cid:image006.jpg@01D4E0C7.8E40C470][cid:image007.jpg@01D4E0C7.8E40C470]
- The failure happen while perform Download Firmware.
- The test program shown E8251-60666 “Eeprom header read from UUT does NOT match header written to UUT.
- Refer to the schematic, U101 is the configuration Eeprom.
- We have perform measurement VOLTAGE for U101, good vs bad.
[cid:image010.jpg@01D4E0C7.8E40C470]
U101 Measurement Voltage (V)
No
U101
GOOD
BAD
1
Pin 1
3.35v
3.30v
2
Pin 2
3.38v
3.30v
3
Pin 3
0
0
4
Pin 4
0
0
5
Pin 5
3.26v
3.30v
6
Pin 6
0
0
7
Pin 7
0
0
8
Pin 8
3.30v
0.035v
9
Pin 9
3.30v
0.035v
10
Pin 10
0
0
11
Pin 11
2.8v
2.79v
12
Pin 12
3.26v
3.30v
13
Pin 13
3.30v
3.30v
14
Pin 14
3.30v
3.30v
15
Pin 15
0
0
16
Pin 16
0
0
17
Pin 17
0
0
18
Pin 18
3.30v
3.30v
19
Pin 19
3.30v
3.30v
20
Pin 20
3.30v
3.30v
No
No
We have done swapping experiment, the failure is following device.
Thank you.
Nabilah
Hi Wani,
Any update on below request?
Pls help to respond this ASAP as we need the disposition on this FA request urgently.
Thank you.
Nabilah
Hi Nabilah,
I believed you have received ERMA support through our private message.
If you have any concern on your ERMA request, you can drop your note to that private message so we can assist you with your needed.
Have a great day!
Thanks!
Wani
