Programmable Devices
21615 Discussions
What's the means"Verify failed between address .. and .."??
Hi !
I want to know about how Nios-IDE show the information "verify failed between address XX and XX",and why??
It verify what??:confused:
pofeng
From the litle info you supply, I guess you are debugging a target and doing a download. After downloading the code, IDE verifies that it actually stored correctly by doing a readback. Somehow it did not store correctly. This can be due to many things. Check that your target is up to date and do pass timing verification. If your hardware is not functioning correctly this could be the result.
I want to know nios_ide verify what then it show me verify failed!
