21607 Discussions
Please help with flash configuration
hello,
i try to send data to flash but it does not work (DE1 board).
i did not use cfi or nios, just program the FPGA.
the configuration is
--oe we ce reset
--H L L H
the pin out is:
FL_ADDR[0] PIN_AB20
FL_ADDR[1] PIN_AA14
FL_ADDR[2] PIN_Y16
FL_ADDR[3] PIN_R15
FL_ADDR[4] PIN_T15
FL_ADDR[5] PIN_U15
FL_ADDR[6] PIN_V15
FL_ADDR[7] PIN_W15
FL_ADDR[8] PIN_R14
FL_ADDR[9] PIN_Y13
FL_ADDR[10] PIN_R12
FL_ADDR[11] PIN_T12
FL_ADDR[12] PIN_AB14
FL_ADDR[13] PIN_AA13
FL_ADDR[14] PIN_AB13
FL_ADDR[15] PIN_AA12
FL_ADDR[16] PIN_AB12
FL_ADDR[17] PIN_AA20
FL_ADDR[18] PIN_U14
FL_ADDR[19] PIN_V14
FL_ADDR[20] PIN_U13
FL_ADDR[21] PIN_R13
FL_DQ[0] PIN_AB16
FL_DQ[1] PIN_AA16
FL_DQ[2] PIN_AB17
FL_DQ[3] PIN_AA17
FL_DQ[4] PIN_AB18
FL_DQ[5] PIN_AA18
FL_DQ[6] PIN_AB19
FL_DQ[7] PIN_AA19
FL_OE_N PIN_AA15
FL_RST_N PIN_W14
FL_WE_N PIN_Y14
reset PIN_L22
led PIN_R20
clk50 PIN_L1
Flash_CE_N PIN_AB15
