21615 Discussions
What should I do if I see this message in the Qsys parameter message?
What should I do if I see this message in the Qsys parameter message? Is it a support issue?
https://alteraforum.com/forum/attachment.php?attachmentid=15677&stc=1
<Error Message >
Info: Platform Designer Tip: Please Sync All System Infos before attempting to resolve the following error messages
Error: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: The current value "Avalon-MM with DMA" for parameter "Application interface type" is invalid under setting Interface Width="64-Bit".
Error: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: The current value "Avalon-MM with DMA" for parameter "Application interface type" (interface_type_hwtcl) is invalid. Possible valid values are: "Avalon-ST" "Avalon-MM". . Rule(s): interface_type_hwtcl.
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: device_family is Cyclone 10 GX
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: base_device is NIGHTFURY1
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: part_trait_device is 10CX150YF672E6G
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: Inside validate_wrala_hwtcl
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: wrala_hwtcl is 6
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: app_interface_width_hwtcl is 64-bit
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: link_width_hwtcl is x1
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: lane_rate_hwtcl is Gen1 (2.5 Gbps)
Info: pcie_qsys_pcie_a10_hip_0.pcie_a10_hip_0: Gen1 (2.5 Gbps) x1 64-bit
Hi. Looks like it doesn't like the 64 bit wide DMA setting. Is 64 bit allowed and compatible with the other blocks? Can you try setting DMA to 32 bit?
Hi. BillyZDSP
I am trying this for the first time.
I used the samples included in qsys PCIe HardIP.
How can I set DMA to 32bit?
Is there a component that can set DMA?
I have a PCIe RC configured as a master and want to link gen1x1 of the cyclone 10 [EP] via the backplane.
The RC uses 32bit address structure. How can I link?
