21616 Discussions
Why should I learn Qsys/Platform Designer
I've created digital designs for 5+ years. I have never used Qsys. I've written HDL modules, manually wired them, did timing analysis and eventually synthesize them. I never found the need to use Qsys.
Am I missing out on any benefits?
Why should I use Qsys?
--- Quote Start ---
--- Quote End ---
Basically it is meant to have several ips generated (as well as clock, reset generation) under one roof and wired together instead of module by module ip generation by the wizard. It also adds addressing map for memory mapped systems. All wiring between such modules are invisible unless you export them.
So in principle it is meant to phase out wizard for a complete subsystem and all such changes are forced on us...
Check out this free online training for details on the benefits of Platform Designer:
https://www.altera.com/support/training/course/oqsys1000.html
Also note that some IP, such as Nios and the Hard Processor System, require Platform Designer.
--- Quote Start ---
--- Quote End ---
Oh my … I thought Qsys was the latest greatest as they claimed at the time.
Platform Designer is Qsys. It's just a name change.
hello ghertz
could you tell us what kind of system have you designed?
Mostly Firmware. Device models. Mostly reading documentation and implementing stuff. VGA videogame....I guess if I haven't had the need to use Qsys....I haven't designed complicated stuff....looking into it now
If you want to design with lots of Altera IP modules, and just have them wired together, with a bit of your logic, then Qsys/PlatformDesigner is a reasonable way to go.
However (as I do) you tend to use very little (if any) of the canned Altera IP modules, then Qsys/PD is basically irrelevant and provides no real added value.
So it depends on what you are trying to do, and how you plan to do it.
--- Quote Start ---
--- Quote End ---
I don't know if I'd totally agree with that.
Even if you don't use Intel FPGA IP, you can create your own custom components and connect them together, relying on the interconnect automatically created by PD instead of building it all yourself.
if you think you are fine with it, that should be fine.
but I ( and many people ) recommend to use Qsys at least once.
then, if you think it is meaningless for you , you don't have to use it anymore.
--- Quote Start ---
--- Quote End ---
This is certainly true. However, in my world I tend to move my code between various development boards using a mix of Xilinx and Altera parts. So I try and keep my HDL as cross platform compatible as possible, and not lock myself into a single vendors tool suite. If you don't care about doing this, then using QSYS for your own modules could make sense.
