20725 Discussions
Where can find "Bare metal C++ example project for Cyclone V SoC Dev Kit" ?
hi,
Does anybody know how to create a "bare-metal hello world C++ project" that can running on Cyclone V SoC Dev Kit ?
I have create a new C++ project from DS-5 IDE, after modify some project properties can build successfully.
But after using DS-5 debugger, it will cause system reset.... I don't know how to solve this.
Can someone help ?
Many thanks in advance.
Create C++ project flow:
1. (SoCEDS 14.1)Embedded command shell
2. open ds-5 (@ eclipse &)
3. File->New Project-> Hello World C++ Project, ToolChain = GCC for ARM bare-metal. Named project as "gccbm"
4. Right-click on project "gccbm", select "Properties"
5. Expend "C/C++ Build", In "Tool settings" sheet
- GCC C++ Compiler\ = arm-altera-eabi-g++
\Target = cortex-a9
- GCC C++ Linker \ = arm-altera-eabi-g++
\Image : set Link Script = C:\altera\14.1\embedded\host_tools\mentor\gnu\arm\baremetal\arm-altera-eabi\lib\cycloneV-dk-ram-hosted.ld
Console message of "Cyclone V SoC Dev Kit" :
U-Boot 2013.01.01 (Jan 14 2015 - 13:14:15)
CPU : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
SF: Read data capture delay calibrated to 3 (0 - 7)
SF: Detected N25Q512 with page size 65536, total: 67108864
In: serial
Out: serial
Err: serial
Net: mii0
Hit any key to stop autoboot: 0
SOCFPGA_CYCLONE5# undefined instruction
pc : [<ff001014>] lr : [<3ff8d791>]
sp : 3ff35638 ip : 3ffaa5b8 fp : 00000001
r10: 3ffa2b7a r9 : 3ffac4bc r8 : 3ff35f60
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000000
Flags: nZcv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
After some modification, now I can do DS-5 Debugging....
1. Add a new debug script (debug-hosted.ds), (attached)
- Run preloader first (semi-host enabled)
- Run gcc_bm.axf
2. Modify debug-configuration
- Debugger Sheet:
Run Control : Connect Only
Run target initialization debugger script: debug-hosted.ds
You have questions or make sample for us ?
I download 2 your files, unzip, import in DS-5, try to compile -- see error:
--- Quote Start ---
make: *** No rule to make target 'gcc_bm.axf', need by 'all'. Stop.
--- Quote End ---
For making any my new projects I use Altera-s examples: need be rename old names in ".cproject" and ".project", "Makefile". Renaming of .c-file to .cpp usually is not disturb.
hi WitFed,
Firstly, I am asking someone to provide an example.
And, I have trying to create one for by myself.
I am putting the correct PROJECT in the post as attachment.
[environment]
Tool: SoCEDS 14.1 & DS-5 AE
KIT: Cyclone V SoC Dev Kit
[Step]
1. download "C:\altera\14.1\embedded\examples\hardware\cv_soc_devkit_ghrd\output_files\soc_system.sof
2. Open DS-5, Import project "mycpp_proj"
3. Build project
4. DS-5 set Debug Configuration
Run Control: Connect Only
Run Debug initilization scription: debug-hosted.ds
