21615 Discussions
cyclone 3 PLL[1..4]_CLKOUTp
Hello to all!
I'm reading the "Pin Connection Guidelines" for cyclone3 and cyclone4E.
In cyclone3 doc i read : "These pins can only use the differential I/O standard if it is being fed by a PLL output"
In cyclone4 doc i read: " Each pin can be assigned to single-ended or differential I/O standards if it is being fed by a PLL output"
I have a cyclone3 custom board, and i need to use a PLL output pin in a single-ended 3.3 LVTTL mode.
Can i do it?
Or i need to change my cyclone 3 to a cyclone4E?
Yes, you can use dedicated PLL outputs in single ended mode on a cyclone3. This is not inconsistent with the statement "These pins can only use the differential I/O standard if it is being fed by a PLL output".
Tnx gj_leeson.
In cyclone 3 if i use a clkoutp in single ended, can i use the associated clkoutn for general pourpose I/O pin?
You will be able to use both clkoutp & clkoutn as independent general purpose, single ended I/O.
Can I assume you want to drive clkoutp from the PLL?
Yes, you should be able to both drive clkoutp (as a single ended signal) from the PLL and use clkoutn as a general purpose I/O pin.
I've just tried this, successfully, albeit with a Cyclone IV part - I don't have Cyclone III installed. It will quite happily allow me to use clkoutn as an input or output signal whilst using clkoutp as a single ended PLL output signal.
Put a small project together and let Quartus give you the answer for Cyclone III.
Cheers,
Alex
By the way, one quick way to find out if a pin assignment is valid or not is to use the pin assignment editor. It will tell you if you're doing something illegal.
