21604 Discussions
Which PINs are related to the programming of the 10M02SCM153C8G?
MartinMaa
My board is very small, so for the part of burning the program code into the 10M02SCM153C8G, I will connect the relevant pins. It is still processed through the USB DOWNLOAD CABLE (JTAG MODE). May I ask, besides connecting the JTAG to the corresponding PIN of the USB DOWNLOAD CABLE, are there any other PINs that need to be noticed and processed?
Is it possible that I use a board with an IC SOCKET, which may only have 5V to 3.3V for MAX10, and then connect this board to the USB DOWNLOAD CABLE, and can I also burn the program code?
FvM
USB download cable isn't sourcing power, there's no supply pin included in the 10 pin JTAG header. You could make a custom specific download adapter that includes supply.
NurAiman_M_Intel
You may refer to Max 10 pin connection guidelines for references:
https://www.intel.com/content/www/us/en/docs/programmable/683232/current/fpga-pin-connection-guidelines.html
Aiman
MartinMaa
Hi, Aiman
Can I directly program the MAX10 through the USB DOWNLOAD CABLE? Can the USB DOWNLOAD CABLE be used as a power source during programming?
VCC(TGRT) ? Can this pin for device power source for device during programming?
FvM
NurAiman_M_Intel
Please follow the pin connection guidelines given to ensure smooth operation.
@FvM is correct.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
