Programmable Devices
21615 Discussions
Which boards support HIL in Matlab/Simulink?
I tried a self made one, but it shows in the Matlab Command Window
No device found from JTAG cables. Make sure the DSP Development Board is attached and switched on
Does it mean that I need a DSP Development Board to do HIL ?
That would cost alot
any alternatives?
thanks in advance!
Assuming you're using HIL in DSP Builder, then any board with JTAG should work. Can you see the board in the Signal Compiler when you scan devices?
--- Quote Start ---
--- Quote End ---
I've figured it out, something is wrong with the JTAG chain,thank you anyway
