21611 Discussions
Why can't generat EP3C55F780C6 pof file in QUARTUS9.0SP2
we use EP3C55F780C6 in our design ,and use ip fft9.0,
but generate sof file ,no pof file ,why?
thanks!
mail: cjfwindy@163.com
--- Quote Start ---
thanks!
--- Quote End ---
which Quartus version do you us ? In case your are using the Web-Edition the use of the FFT function is limited to 1 hour after programming the device.
"Warning: Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed
Info: Evaluation period of megafunction that supports OpenCore Plus feature can be extended indefinitely by using tethered operation"
That is the reason why you can't generate a pof-file.
Kind regards
GPK
Assembler report for cip90-c3
Sun Nov 01 00:51:58 2009
Quartus II Version 9.0 Build 235 06/17/2009 Service Pack 2 SJ Full Version
; Table of Contents ;
1. Legal Notice
2. Assembler Summary
3. Assembler Settings
4. Assembler Generated Files
5. Assembler Device Options: E:/FPGA/cip90-c3/cip90-c3.sof
6. Assembler Messages
thanks
Did you get a "<project_name>_time_limited.sof" file. If you are using OpenCore evaluation for any IP cores, you will not be able to generate a POF file.
Jake
I don't get "<project_name>_time_limited.sof" file.
but get
E:/FPGA/cip90-c3/cip90-c3.sof file
is right?
thanks
As you are apparently using a subsription license, that includes the FFT core: Did you select "Use configuration device" in the Device and Pin Options/Configuration" tab?
You should be also able to convert *.sof to *.pof by the Convert Programming Files tool.
1.You should be also able to convert *.sof to *.pof by the Convert Programming Files tool
what is the Convert Programming Files tool?
2.I didn't selected "Use configuration device" in the Device and Pin Options/Configuration" tab
