Programmable Devices
Wm8731
Hello people,
Is there anyone who has experience working with WM8731 on DE2 board.
I want to know the following:
Is there any possibility to use WM8731 as a ADC(Analog to Digital Converter)?
I have analog signal and I need to do ADC conversion with DE2 board.
Thank you very much for your time and effort.
Bojan:)
It's designed for AC operation and doesn't have a DC accuracy as known from instrumentation and measurement ADC. Automatic zero restore can possibly be used to improve it's behaviour in a measurement application.
Does it means that I could use WM8731 for my own application like A/D converter?
The signal that I want to convert is DC signal within a range [0 to 1.4 V].
All the best.
Bojan
The signal has to be DC-shifted to WM8731 input range. At a DE2 board, you must short the line input AC coupling.
it's the firt time i use DE2 kit,i written some code for LCD,switch,LED.but i want to generate a music by read from SDRAM.i can't understand WM8731.everyone can explain funtion of wm8731 for sound. thank you so much !
