Programmable Devices
20844 Discussions
Woodward-Request for MDDS<179571>
SMude
Dear Team,
Greetings!!!
Can you please provide us the MDDS document for below listed devices. I was unable to find the same in MDDS database.
Mfr Part Number
EP1C4F400C8ESN ( N=PBFREE )
EPM7032LI44-10N
EPM7032SLI44-10
EPM7032SLI44-10N
EPM7064SLI84-10
Zawani_M_Intel
Hi SMude,
Thank you for using Intel FPGA Community Forum.
Please download your MDDS here :
https://www.intel.com/content/www/us/en/collections/content-type/mdds.html
You can the xml in excel by opening it via developer tool, see instructions below.
How to open xml file in Excel:
  1. Open a new blank Excel file
  2. Click on Developer tab, then click Import
  3.  Select the xml file you want to import, then click Import
  4. Click "OK" on pop-op information, and also "OK" on where to Import data
  5. The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
  6. I recommend to delete column AK so that the other columns will display better.
Thank you!
Wani
SMude
Dear Wani,
Thank you, I am unable to find MDDS for these devices . Can you please attach these documents.
Note:- I followed all the steps you described. However no success.
SMude
Dear Wani,
