Hi SMude,
Thank you for using Intel FPGA Community Forum.
Please download your MDDS here :
https://www.intel.com/content/www/us/en/collections/content-type/mdds.html
You can the xml in excel by opening it via developer tool, see instructions below.
How to open xml file in Excel:
- Open a new blank Excel file
- Click on Developer tab, then click Import
- Select the xml file you want to import, then click Import
- Click "OK" on pop-op information, and also "OK" on where to Import data
- The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
- I recommend to delete column AK so that the other columns will display better.
Thank you!
Wani
Dear Wani,
Thank you, I am unable to find MDDS for these devices . Can you please attach these documents.
Note:- I followed all the steps you described. However no success.
Dear Wani,
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
Topic Options
