21611 Discussions
a problem about fir design using dspbuilder
I want to design a fir filter with dspbuilder,but the result is not correct,I'm very confused.
The following are the parameter I want to reach:
The source signal is sythesis of a sin signal which frequency is 200HZ and a sin signal which frequency is 5000HZ.I want to design a low filter.so that I want to see only the 200HZ signal after the sounce passed the filter.The sample frequency is 20000HZ.
AP:1db AS:30db
I use the kaiser window with beta=0.5
I will show the whole design with my .mdl file,expect your response as soon as possible!
Thanks for any help. I'm a freshman in filter design.
The problem has been solved by myself,thank you all the same!
how did u do it can you tell me please
