21611 Discussions
access the on-chip memory block in Fabric from HPS in Cyclone V SoC
I am building a system with HPS-to-FPGA AXI bridge enabled, and connecting a on-chip memory(dual port RAM, created from Altera library) in the fabric. I know the HPS-to-FPGA bridge support bursting, but does the on-chip memory support bursting? And I want to move data between the HPS DDR3 memory and the on-chip memory in fabric, what is the most efficient way to implement it? Thanks.......
JSBruno
I am working on a project in which I need to do something like this, have you found the solution?
Thanks in advance.
