21610 Discussions
agilex 7 - DPR size
zeev_gerber
who to reduce DPR size in agilex 7.
configuration:
dual port memory
read/write in each port
different clocks per ports (clock A and clock B)
i work with dual buffer.
port A and B didn't work in the same time.
I have 48 units with size of 16384 X 32.
currently the size is huge and I couldn't compile the devise.
pls. advise
Zeev Gerber
AdzimZM_Intel
Hi Zeev Gerber,
Can you provide the information about the error you're facing?
What is mean by reduce DPR size?
Which design that you're working one?
Adzim
AdzimZM_Intel
Hi Zeev Gerber,
Any feedback on this thread?
Adzim
