21615 Discussions
all bins on tristate
Im working on a project with MAXV
i got the pcb and soldered the cpld and it accept programming
but all the pins give different voltages 0.9 1.7 2 v
the Quartus 2 give successful build for they synthesis and the fitter
but the bins should output ground not floated with random voltage
is there any option
or something i miss
thankyou
i tested the io banks , 1 bank works well when assign it to vcc or to gnd
the other io bank when assigned to vcc works
but when assigned gnd it floats
What is the package you are using? You mention it was hand soldered. Is this on a known-working PCB design, or is it a new one?
The behavior you indicate would seem to be related to assembly and/or design, and not necessarily an FPGA programming issue per se.
its my pcb design
after testing it should be a unconnected bank ground pins so when the input circuitry connect it to ground its float
but i test all ground pins and all of them are connected well , dont know why, but i will do more testing
im using 5m240zt100c5
