hi
i'm a sw engeneer involved in development of code using several api altera functions ..in detail i need "altera_hwif_mutex.h" and i'm not able to find it. someone else can help me?? regards luigiLink Copied
I'm not able to find any reference to the file you mention. Are you sure you're question is correct? What hardware are you expecting to control?
problem solved.that file doesn't belong to an official delivery but is private file used in an embedded application.
Topic Options
