21615 Discussions
apper "does not have byteenables" when customize a IP ?
Warning: cpu_0.data_master/Altera_UP_Avalon_Character_LCD_0.avalon_slave_0: Altera_UP_Avalon_Character_LCD_0.avalon_slave_0 does not have byteenables. Narrow (less than 32-bit) writes from cpu_0.data_master will result in spurious writes to Altera_UP_Avalon_Character_LCD_0.avalon_slave_0
when I use several files in altera_up_avalon_character_lcd floder of University_Program to customize this IP , Appear the above problems, can anyone help me? Thank you very much!
It isn't a problem, it is just a warning. If you plan to always do 32-bit access to the component then you won't have any problems. If not, then you will have to add the byte enable signals to the Avalon MM slave interface and use them.
