i need to desgin a system board for FPGA stratix4 the goal of the board is to check the device(check if the device work properly), i need some help ,advices and materials...
do the JTAG help me??? thanks....Link Copied
You should probably best contact your Altera FAE and ask if it is possible to provide information on the Altera test vectors / test utilities for the Stratix IV.
first thank you,
how can i contact Altera FAE and ask if it is possible to provide information on the Altera test vectors / test utilities for the Stratix IV ??? http://www.alteraforum.com/proweb/buttons/quote.gif (http://www.alteraforum.com/forum/newreply.php?do=newreply&p=74663)- Mark as New
If you ask your local Altera distributor, they should be able to put you in touch with an FAE.
