audio problem
how can i connect audio codec wm8731 to the filter fourier transform !!!
how can i send the audio from the microphone to the filter fft fourier transform then to the headphone!!!
the first part il works very well i can speak with the microphone and then i listen my self from the headphone but i need to send the voice from the microphone to the filter then to the headphone and i listen to the voice that will be changes
i need a help please
As I can see from your code, in the "audio.vhd" file, you are storing the data in "AUD_DACDAT" to send it out to the D/A Converter for headphones. Before doing that, you can invoke your filter. It should be fairly simple. I have modified the "audio.vhd". You can see the changes I have made under the tags "CHANGED". I did not compile it but it should be able to do what you ask.
Berk
think you for your help i try it but unfortunately i still listen to the initial voice there is no effect of the filter fft .
this is my program with modifications . You can see it and can you propose any thing
--- Quote Start ---
Berk
--- Quote End ---
please can you help me and verify with me this code
i use DE1 board i want to realize an audio project which i want to recorder my voice with the microphone in the sd card and then i want to listen to the voice which is recorder in the sd card
please any help i want a code in vhdl
i have a proposition that allows to speack in the mic and in the same time i listen to my self with the headphone . this part works very well i configure the audio codec via i2c and it works very well but i want to recorder the voice in the sd card if i press to key1 and then if i press key2 i listen to the voice from the sd card please i want some help
this is my code
ANY HELP
Hello ,
i use DE1 board of FPGA (CYCLONE 2) i want to realize an audio project which i want to recorder my voice with the microphone in the sd card and then i want to listen to the voice which is recorder in the sd card
please any help
i have a proposition that allows to speack in the mic and in the same time i listen to my self with the headphone . this part works very well but i want to recorder the voice in the sd card if i press to key1 and then if i press key2 i listen to the voice from the sd card
ANY HELP
this is the code vhdl of sdcard
http://devbisme.webfactional.com/content/accessing-xula2-microsd-card
https://github.com/xesscorp/xula/blob/master/fpga/xula_lib/sdcard.vhd
i want to do the link between audio code and sdcard code
any help this is my code vhdl i want some who help me to verify with me this code
