21611 Discussions
bemicro MAX 10 board time constraint
am working on adding the SLS SD/eMMC card adapter to my BEMICRO MAX 10 board, the tutorial was originally written for cyclone III... Was wondering if anyone knew if the timings had to change
heres a shot of the PDF
http://www.alteraforum.com/forum/attachment.php?attachmentid=11746&stc=1
the .sdc code reads in the pdf
create_clock -name osc_clock -period 20.833 [get_ports osc_clk]
derive_pll_clocks
derive_clock_uncertainty
is this right ?
Is the frequency of the clock driven into the BeMicro board's 'osc_clk' pin the same as it was on the Cyclone III solution? - i.e. 48MHz. If so, the constraints look fine.
Cheers,
Alex
