21594 Discussions
bit shifting arithmetic
Hi there!
I am trying to get my around some binary arithmetic.
Basically, I don't want to deal with floating points, so I have a problem that was originally
400 * 0.0615 = 24.6
to this
(400*615) >> 4 = 24.6
Except in binary, it doesn't work like this?
for instance,
10 -> 1010
100 -> 1100100
I can't shift it over by simply doing 100 >> 1;
Please help!
Thanks in advance.
--- Quote Start ---
--- Quote End ---
You need to decide. Thinking in base 10, or thinking in base 2. Since you want to do it with simple logic, go with base 2.
Your 'equation' listed above first multiplies by 10^4, then divides by 2^4. That ain't gonna work. Instead of multiplying .0615 by a power of 10, multiply by a power of two (enough to make it an integer), do the math, then shift it back down (divide) by the same power of 2. (or leave it shifted up in preparation for whatever you're going to do next.)
Thanks for the response! That's actually part of the problem because I haven't wrapped my head around thinking in base 2 yet :)
bit shifting is only useful for multiplies when you have only a few 2^n coefficients. for example:
0.75 = 0.5 (2^-1) + 0.25(2^-2)
so 5 x 0.75 = 5x0.5 + 5x0.25
When you have more than a couple, it is more sensible to use a multiplier instead because it can calculate results faster than a large adder chain.
thanks. i decided to use division instead :)
Division is best avoided on FPGAs. If you can, it is usually much cheaper and faster to multiply by 1/n rather than divide by n. (assuming you can calculate 1/n via some other means (on a CPU, inside a lookup table etc)
Back to your original example:
--- Quote Start ---
400 * 0.0615 = 24.6
to this
--- Quote End ---
Instead of multiplying 0.0615 by 10000, multiply by a power of 2. For example:
= 400 * (0.0615 * 2^16) >> 16
= 400 * 4030 >> 16
= 1612000 >> 16
= 24
If you want to avoid floats and still have fractional values, you will have to use fixed point.
