21611 Discussions
block diagram from VHD file
Just wondering if there is a way to generate a block diagram from just a VHD file? I am looking at an old vhd file for the max7000S:EPM7256SQC208 CPLD, also using version 10 web edition of quartus 2.
I think RTL viewer may help you.
yes.
File -> create/update -> symbol file from current file.
Be aware, it only likes certain things on the port map.
Edit - this just creates you a block to put in another graphic file.
For a schematic view of your code, you need the RTL viewer.
thanks for the responses, just wondering is RTL viewer part of the quartus 2 version 10 web edition?
it looks like (create symbol file from current file) is not enabled, any ideas? The VHDL file is around 7 years old.
I was able to find the RTL viewer and get it to work as also found an associated project file.
