These are the sources for the boa webserver with Auth and SSL enabled.
The sources are taken from the Microtronix boa port. I had to tweek some files to make it work. I used the Altera Nios IDE to compile, but compiling with buildroot environment is also possible. Find the whole tutorial at my webpage (http://www.8ung.at/nacide_manfred/linuxtutorial.html#boawebserver)Link Copied
