Dear All,
I was updating the resources for devices in Cyclone family ( IOs, LUTs, Registers ... etc. I was running the Quartus 11.1 release on specific device (e.g. EP1C3T100C6). Analyze the "<TopDesign.fit.summry>" and "<TopDesign>.fit.rpt" files to extract all the available resources. Would you please advise me, how can i get/extract the available Registers and LUTs values for any device such as (EP1C3T100C6) from any of the above files ? If this is not the professional or the right way to get these resources, then what should i do ? p.s. registers should be different than luts. Example for what i am doing to extract the Memory Bits from the "<TopDesign.fit.summry>" . From the following line exist in this file, I parse it and update my memory bits value with 59,904 Total memory bits : 0 / 59,904 ( 0 % ) Thanks in Advance. Best Regards, IslamLink Copied
hi thepancake,
Thanks a lot for your reply. I saw the screen shot. I believe that the registers can be calculated from the line of "dedicated logic register" with the value 99,280. But, the point is, i can't find such field in any file came out from the fitter of Quartus for the cyclone family. So, would you please run the quartus on Cyclone family and see if i can get the "dedicated logic registers" from any of the reports generated ? Thanks in advance.- Mark as New
ah so you don't think it comes out in the text based reports? i'll take a look
