21615 Discussions
can any one help me in VHDL codes plz
Hi all ,
I wanna help to write these 2 codes of the VHDL on Quartus II programme:
1) a structural VHDL code of 1 to 8 Demultiplexers. with an
active low Enable signal using 1 to 2 Demultiplexer. [ use Generate
statement]
__________________________________________________ ____________
2)
a structure or behavior VHDL code of 5-bits binary
counter with a synchronous load signal to preset the counter to a
specific initial state. the output of the counter ( Q0 to Q4) are
connected to a binary decoder that shows the state of the counter.
In our college they did not teach us this programme and they want from us to make these codes in the next 3 days and really i am so poor in the programming, So can any one help me plz :cry:
Hi, are you french ;-) ?
--- Quote Start ---
--- Quote End ---
Did you go to the courses :-D ? Or your teacher is on hollydays.
VHDL is Very High frenquency Integrated Circuit Hardware description language
So, you should have an "intro" to this language.
First, make schema (for beginners).
Second, describe it in VHDL
In Quartus, you have templates. You will find them in Quartus menu.
In the Word Wide Web (thanks to the billions of persons who are connected on and can help a poor lonesome student by freely sharing tons of knowledge....) , there are numerous examples.
Q1) Not easy for pure beginners
first make "n
active low Enable signal using 1 to 2 Demultiplexer"
Q2)
http://en.wikipedia.org/wiki/vhdl
library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; -- for the unsigned type entity counter_example is generic ( WIDTH : integer := 5); -- 5 here :-) port ( CLK, RESET, LOAD : in std_logic; DATA : in unsigned(WIDTH-1 downto 0); Q : out unsigned(WIDTH-1 downto 0)); end entity counter_example; architecture counter_example_a of counter_example is signal cnt : unsigned(WIDTH-1 downto 0); begin process(RESET, CLK) is begin if RESET = '1' then cnt <= (others => '0'); -- async load elsif rising_edge(CLK) then -- synchronous domain below if LOAD = '1' then cnt <= DATA; -- sync load else cnt <= cnt + 1; end if; end if; end process; Q <= cnt; end architecture counter_example_a;
Good homeworks ! (in my opinon, this is the worst way to learn something)
And .......... Good Luck !
hi sir,
yes we took a quick intro and the teacher now is in holiday -_-
really thank you for that :)
one of my references : vhdl syntax : http://amouf.chez.com/syntaxe.htm with few examples
You don't need procedures and functions, neither package.
