21607 Discussions
clkp and clkn inputs in Intel FPGAs
gyuunyuu
The clkp and clkn can be used to insert a differential clock signal into the FPGA. My question is, can we have 2 separate independent single ended clock signals being input into the FPGA on these two pins or just one single ended clock on either of them?
This question is specifically about MAX 10 and Cyclone 10 LP.
Ash_R_Intel
Yes, it is possible to use both P and N pins as independent single-ended clock inputs, in MAX 10 and Cyclone 10 LP devices.
Regards.
gyuunyuu
The different dedicated clock pins feed different GLCK networks. Is the fitter able to link different GCLK networks together so a single pin can feed the whole device? How does it achieve this?
Also, why does fitter allow user to use general purpose I/O pin to input a clock signal?
Ash_R_Intel
GCLK networks are capable driving the entire device. Please refer below documentations:
MAX 10 GCLK network:
https://www.intel.com/content/www/us/en/programmable/documentation/mcn1395213337540.html#mcn1395215177640
Cyclone 10 LP GCLK network:
https://www.intel.com/content/www/us/en/programmable/documentation/sxm1481253171919.html#usl1489986081778
Regards.
