21604 Discussions
code flash error in 5cgxfc7c6f23
Aravindpalanisamy
hai!...
                 I am using 5CGXFC7C6F23 IC, during code flash into controller, programmer setup showing some error like couldnt connect the device. we are using usb blaster 2 programmer ( driver installed )and programmer ide ver: 14.0. During fpga board power down mode as well as power on mode same problem is coming. kindly give your valuable solution  and i have attached the error message image  for your reference.
Thanks &regards
Aravind P
Alberto_Sykes
Aravindpalanisamy, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, just to let you know, I moved your post to the proper department so they can further assist you with this matter as soon as possible.
Albert R.
Aravindpalanisamy
Hai Alberto_r_intel!!.
                                              Last 4 days i am waiting for the reply for my above question but still not received any assistance form your side . Kindly take it as a high priority and suggest me as soon as possible.
Alberto_Sykes
Aravindpalanisamy, Thank you very much for your response.
Let me apologize for any inconvenience, I already transferred the case to the proper department before, I will transfer it once again for them to further assist you as soon as possible.
Albert R.
JohnT_Intel
Could you confirm if the board is power up successfully? Have you try to measure the nConfig, nStatus and CONF_DONE pin?
Have you try the step in https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03312011_647.html?
