21615 Discussions
code not working not sure why. code is posted along with megawizard code.
I am trying to use the megawizard function for the mif.
code:
LIBRARY IEEE;
--USE ieee.std_logic_vector.1164.all;
entity test is
GENERIC(depth: INTEGER := 256; mem_width: INTEGER := 8);
port(
--wr_ena: IN STD_LOGIC;
clk: IN STD_LOGIC;
addr: IN INTEGER RANGE 0 to depth-1;
data_in: IN STD_ULOGIC_VECTOR(mem_width-1 downto 0);
data_out: OUT STD_ULOGIC_VECTOR(mem_width-1 downto 0)
end entity test;
architecture async_ram of test is
component ch_13_ram_2p is
PORT (
address_a : IN STD_LOGIC_VECTOR (4 DOWNTO 0);
address_b : IN STD_LOGIC_VECTOR (4 DOWNTO 0);
clock : IN STD_LOGIC := '1';
data_a : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
data_b : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
wren_a : IN STD_LOGIC := '0';
wren_b : IN STD_LOGIC := '0';
q_a : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
q_b : OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
END COMPONENT;
attribute ch_13_ram_2p: string;
attribute ch_13_ram_2p of myRAM: SIGNAL IS "ch13_ram_2p.mif";
BEGIN
myRAM: ch_13_ram_2p PORT MAP(
clock => clk,
address_a => addr,
address_b => addr,
data_a => data_in,
data_b => data_in,
wren_a => wr_ena,
wren_b => wr_ena,
q_a => data_out_a,
q_b => data_out_b);
END async_ram;
here is the file created from the megawizard plug-in
-- megafunction wizard: %RAM: 2-PORT%
-- GENERATION: STANDARD
-- VERSION: WM1.0
-- MODULE: altsyncram
-- File Name: ch13_ram_2p.vhd
-- Megafunction Name(s):
-- altsyncram
-- Simulation Library Files(s):
-- altera_mf
-- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
-- 10.0 Build 262 08/18/2010 SP 1 SJ Web Edition
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY ch13_ram_2p IS
PORT
END ch13_ram_2p;
ARCHITECTURE SYN OF ch13_ram_2p IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (7 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC_VECTOR (7 DOWNTO 0);
COMPONENT altsyncram
GENERIC (
address_reg_b : STRING;
clock_enable_input_a : STRING;
clock_enable_input_b : STRING;
clock_enable_output_a : STRING;
clock_enable_output_b : STRING;
indata_reg_b : STRING;
intended_device_family : STRING;
lpm_type : STRING;
numwords_a : NATURAL;
numwords_b : NATURAL;
operation_mode : STRING;
outdata_aclr_a : STRING;
outdata_aclr_b : STRING;
outdata_reg_a : STRING;
outdata_reg_b : STRING;
power_up_uninitialized : STRING;
read_during_write_mode_mixed_ports : STRING;
read_during_write_mode_port_a : STRING;
read_during_write_mode_port_b : STRING;
widthad_a : NATURAL;
widthad_b : NATURAL;
width_a : NATURAL;
width_b : NATURAL;
width_byteena_a : NATURAL;
width_byteena_b : NATURAL;
wrcontrol_wraddress_reg_b : STRING
PORT (
clock0 : IN STD_LOGIC ;
wren_a : IN STD_LOGIC ;
wren_b : IN STD_LOGIC ;
END COMPONENT;
BEGIN
q_a <= sub_wire0(7 DOWNTO 0);
q_b <= sub_wire1(7 DOWNTO 0);
altsyncram_component : altsyncram
GENERIC MAP (
address_reg_b => "CLOCK0",
clock_enable_input_a => "BYPASS",
clock_enable_input_b => "BYPASS",
clock_enable_output_a => "BYPASS",
clock_enable_output_b => "BYPASS",
indata_reg_b => "CLOCK0",
intended_device_family => "Cyclone IV GX",
lpm_type => "altsyncram",
numwords_a => 32,
numwords_b => 32,
operation_mode => "BIDIR_DUAL_PORT",
outdata_aclr_a => "NONE",
outdata_aclr_b => "NONE",
outdata_reg_a => "CLOCK0",
outdata_reg_b => "CLOCK0",
power_up_uninitialized => "FALSE",
read_during_write_mode_mixed_ports => "DONT_CARE",
read_during_write_mode_port_a => "NEW_DATA_NO_NBE_READ",
read_during_write_mode_port_b => "NEW_DATA_NO_NBE_READ",
widthad_a => 5,
widthad_b => 5,
width_a => 8,
width_b => 8,
width_byteena_a => 1,
width_byteena_b => 1,
wrcontrol_wraddress_reg_b => "CLOCK0"
PORT MAP (
clock0 => clock,
wren_a => wren_a,
address_b => address_b,
data_b => data_b,
wren_b => wren_b,
address_a => address_a,
data_a => data_a,
q_a => sub_wire0,
q_b => sub_wire1
END SYN;
"0"
code error
Error (10482): VHDL error at test.vhd(8): object "STD_LOGIC" is used but not declared
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 226 megabytes
Error: Processing ended: Sun Apr 17 12:55:48 2011
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 1 warning
click on the firs error I go to the clk:IN STD_LOGIC; line, but I thought that I am setting it equal to clock towards the end???
For now you need to add use statement which is commented out but has syntax error:
it should be like this:
library ieee;
use ieee.std_logic_1164.all;
Thanks helped some but still some errors
What is the error saying?
I don't see why you use that attribute thingy. Just enter the name of mif in megawizard and forget about attributing.
By the way you have dual port but you are wiring it as two copies of single port. That does not matter for now but when you put the finishing touch.
