21615 Discussions
code style for mixed width port dpram
hi,everybody.How to modify this code to generate a mixed width port dpram,
the simplest example such as :
emodule true_dpram_sclk
input [7:0] addr_a,
input [0:0] data_a,
input [4:0] addr_b,
input [7:0] data_b,
input we_a, clk,
output reg q_a,
output reg [7:0] q_b
// Declare the RAM variable
reg [0:0] ram[63:0];
// Port A
always @ (posedge clk)
begin
if (we_a)
begin
ram[addr_a] <= data_a;
q_a <= data_a;
end
else
begin
q_a <= ram[addr_a];
end
end
// Port B
begin
q_b[0] <= ram[{addr_b,3'd0];
q_b[1] <= ram[{addr_b,3'd1];
q_b[2] <= ram[{addr_b,3'd2];
q_b[3] <= ram[{addr_b,3'd3];
q_b[4] <= ram[{addr_b,3'd4];
q_b[5] <= ram[{addr_b,3'd5];
q_b[5] <= ram[{addr_b,3'd6];
q_b[7] <= ram[{addr_b,3'd7];
end
endmodule
This code works ok,but it get more alms and other resources in ep2sxx .
When i used Megawizard to generate the same funciton LPM,and it just waste one m4ks.
Now the situations is i can't used the LPM code,how can i changer my verilog code style get the the same result of LPM. Please help.thanks a lot!
The reference code is :
input [7:0] data_a, data_b,
input [5:0] addr_a, addr_b,
input we_a, we_b, clk,
output reg [7:0] q_a, q_b
reg [7:0] ram[63:0];
// Port A
begin
if (we_a)
begin
q_a <= data_a;
end
else
begin
q_a <= ram[addr_a];
end
end
// Port B
begin
if (we_b)
begin
ram[addr_b] <= data_b;
q_b <= data_b;
end
else
begin
q_b <= ram[addr_b];
end
end
endmodule
Hunger for your answer!haha.................That sounds really upset,right?What about the altera FAE?Have they seen that?
Please use direct instantiation instead of inferrence.
AFAIK is the only way to achieve mixed width port dpram
in this case it should be submitted to Altera as a synthesis enhancement.
