comparator
i need to do
Greater or equal than
Less or Equal than
not equal
but it is not working with me
could you check this code i have done greater or equal than but it is not workin but aeqb,agtb,altb are working correctly
library ieee; USE ieee.std_logic_1164.ALL; entity compare8 is port( a,b : IN INTEGER RANGE 0 to 255; agtb,aeqb,altb,ageqb : OUT STD_LOGIC ); end compare8; architecture a of compare8 is SIGNAL compare : STD_LOGIC_VECTOR (3 downto 0); BEGIN process(a,b) BEGIN if a > b THEN compare <= "1110"; ELSIF a < b THEN compare <= "1101"; ELSIF a = b THEN compare <= "1011"; ELSIF ( a >= b ) THEN compare <= "0111"; ELSE compare <= "1111"; END IF; END PROCESS; agtb <= compare(0); altb <= compare(1); aeqb <= compare(2); ageqb <= compare(3); end a;
if a > b THEN compare <= "1110"; ELSIF a < b THEN compare <= "1101"; ELSIF a = b THEN compare <= "1011"; ELSIF ( a >= b ) THEN compare <= "0111"; ELSE compare <= "1111"; END IF;The conditions in an IF statements are evaluated in order. The ">=" case in your code will never trigger as in that case either ">" or "=" will always be evaluated first.
so how can i use greater or equal than
could you check this page please
http://eesun.free.fr/doc/vhdlref/refguide/language_overview/objects__data_types_and_operators/vhdl_operators.htm
--- Quote Start ---
--- Quote End ---
could you explain more what u mean by this, sorry ican't understand what u mean exactly
Hi Fedail,
Why not making this way?
process(a,b) BEGIN IF (a < b) THEN altb <= "1"; ageqb <= "0"; agtb >= "0"; aeqb <= "0"; ELSIF(a = b) THEN altb <= "0"; ageqb <= "1"; agtb >= "0"; aeqb <= "1"; ELSE altb <= "0"; ageqb <= "1"; agtb >= "1"; aeqb <= "0"; END IF; END
--- Quote Start ---
--- Quote End ---
All if/elsif/else paths are mutually exclusive. Because ">=" will also trigger the ">" or the "=" branch, you will never end up in the ">=" branch. You can only go down 1 branch.
aha i got it
i'll try another way
i solve the problem wih other way
if a > b THEN compare <= "010110"; ELSIF a < b THEN compare <= "001101"; ELSIF a = b THEN compare <= "100011"; ELSE compare <= "111111"; END IF; END PROCESS; agtb <= compare(0); altb <= compare(1); aeqb <= compare(2); ageqb <= compare(3); aleqb <= compare(4); anotb <= compare(5);
put could you check this image please why this happened with me i mean this small spike
http://i25.tinypic.com/hreuzo.png
could anyone help me with this please
because you havent synchronised it.
Fedail,
the glitches in the output occur because your design is purely combinatorial. Changes of input signals have different paths to the output, hence the glitches.
--- Quote Start ---
Tricky:
--- Quote End ---
If you register the outputs you will not have those glitches anymore. But now beware of setup times ...
which one should i synchronised and how
This is rather basic knowledge, but I'll humour you.
You might invest in a few good books on VHDL, I suggest you get a copy of:
Circuit Design with VHDL
by Volnei A. Pedroni
ISBN 978-0-262-16224-1
process( Clk ) begin if rising_edge( Clk ) then IF a > b THEN compare <= "010110"; ELSIF a < b THEN compare <= "001101"; ELSIF a = b THEN compare <= "100011"; ELSE compare <= "111111"; END IF; end if ; END PROCESS;
very thanks i am still learning with some book for DUECK
